favoritesbutton
HELPER
The favoritesbutton statement handles the Favorites button in a dialog.
helper – name of the helper procedure. This procedure must contain subroutines named GETFAVORITES:
, WRITEFAVORITES:
, GETSPEC:
, SETSPEC:
and NEWFAVORITEDEFAULTNAME:
. Usually these can be tucked away in the same procedure that handles the buttons for the dialog. If the helper procedure is not specified then the procedure is assumed to be called FavoritesHelper.
- automaticfieldname( -- returns an available field name.
- Field Blueprint Dialog -- examining and modifying the raw specification of a field.
- fieldalignment( -- returns the alignment of a database field.
- fieldformula( -- returns the formula associated with a database field.
- fieldnumber( -- returns the number of a database field (starting with 1).
- fieldpattern( -- returns the output pattern associated with a database field.
- fieldtypes( -- returns a carriage return delimited array with a list of the fields and field data types.
- fieldwidth( -- returns the width (in the data sheet) of a database field.
- hiddenfields( -- returns a list of hidden fields in the curent data sheet window
- visiblefieldnumbers( -- returns a data array of visible fields (by number) in the data sheet.
- visiblefields( -- returns a list of visible fields in the data sheet.
