letglobal
VARIABLE
VALUE
The letglobal statement creates a global variable and assigns a value to it.
variable – is the name of the variable that you want to create or an existing variable to which you want to assign to a new value.
value – calculates the value that will be placed into the variable.
This statement works just like an assignment, but the destination of the assignment is automatically created as a global variable. For example, this statement creates a global variable named pageCount and assigns the value 23 to it.
letglobal pageCount=23
The value can be any data type, for example text like this:
letglobal userName="Bob"
If the variable already exists, any value it contains is replaced.
Note: This statement is identical to the assignglobal statement, but letglobal uses an equal sign between the variable name and the value, instead of a comma.
