popupbelowbutton
LIST
INITIAL
CHOICE
The popupbelowbutton statement displays a pop-up menu in response to clicking on a button.
list – Carriage return separated array of choices to appear in pop-up menu.
initial – Initial choice to be selected in pop-up menu (or "" if no choice).
choice – Item user selected in pop-up menu (or "" if no choice). Note: If the menu was constructed with identifiers you can also use the info(“menuidentifier”) function to determine the chosen menu item.
This statement can be used to produce a pop-up menu in response to clicking on a button. The menu will pop-up under the button that was pressed. It is intended that this statement be used in a procedure that is triggered by a button on a form (or any form object that triggers a procedure). The procedure must be triggered on mouse down, not mouse up.
Here is an example that displays a pop-up menu with three colors when the button is clicked.
local colorChoice
popupbelowbutton "Red"+cr()+"Green"+cr()+"Blue","Red",colorChoice
// colorChoice now contains the color name
