exportallprocedures
DATABASE
DICTIONARY
The exportallprocedures statement saves all the procedures in an editable text format.
database – Name of the database, or “” for current database.
dictionary – Field or variable to store result in.
This statement saves all the procedures in an editable text format.
ExportAllProcedures "",myProcedureSources
Later, you can use the importdictprocedures statement to bring the procedures back into a database.
Note: For new applications, the saveblueprint statement provides improved functionality over the ExportAllProcedures statement.
