showrectangle
AREA
The showrectangle statement refreshes all or part of the current form window.
area – is the rectangle to refresh (in form coordinates). If this is a zero height and width rectangle the entire form is refreshed Note: You can repeat this parameter to refresh multiple areas.
This statement refreshes all or part of the current form window. This example refreshes a 1 inch high by 2 inch wide area in the top left corner of the form.
showrectangle rectangle(0,0,72,144)
This example refreshes three 1" squares on a diagonal from the upper left.
showrectangle rectangle(0,0,72,72),rectangle(72,72,72,72),rectangle(144,144,72,72),
This example refreshes the entire form.
showrectangle rectangle(0,0,0,0)
In most situations it’s better to use other methods to refresh the form, for example showvariables, showwindowvariables, showfields, etc. However, if there is no field or variable involved, you can perform the refresh using the showrectangle statement. For example, you can use it if you want to make several changes to graphic forms without causing excessive “flashiness”.
noshow
new form object
move form object
delete form object
change form object
showrectangle area-that-changed
endnoshow
- @forms --
