dropallshareddatabases
The dropallshareddatabases statement drops the connection to all shared databases. Panorama uses this when the client is about to quit, could also be used if you know you are about to go offline.
This statement drops the connection to all shared databases. If you have databases open on multiple servers, all of them will be disconnected. Panorama uses this when the client is about to quit, could also be used if you know you are about to go offline. Note: This does not close the databases on the local client, they remain open in read-only mode.
10.2UpdatedNew in this version.
