The adjustobjectspacing statement adjusts the spacing of selected objects in a form.
This statement has two parameters:space – amount of space to be placed between each object in the form (in points)
direction – Direction of objects, either Vertical or Horizontal (these may be abbreviated to V or H). If this parameter is omitted, vertical is assumed.
This statement adjusts the spacing of selected objects in a form, placing a fixed amount of space between every object. This example assumes a vertical column of objects is selected, it then spaces them apart by 12 points.
adjustobjectspacing 12,"Vertical"
This example assumes a horizontal column of objects is selected, it then spaces them apart by 6 points.
adjustobjectspacing 6,"Horizontal"
This statement can also be used with a grid of objects. As long as the objects in the grid are all aligned exactly on the same grid, it will preserve the grid alignment while changing the spacing.
10.1.1 | New | New in this version. |
