The speechscripts statement returns a lists of speech scripts in a database.
This statement has two parameters:database – database that contains the scripts you want to list (the database must be open). If this parameter is empty, scripts in the current database will be listed.
scripts – field or variable where the list will be placed. The list will contain one script name per line (carriage return separated).
This statement returns a lists of speech scripts in a database (if any). This example loads the list of scripts into a local variable named speechChoices.
local speechChoices
speechscripts "My Contacts",speechChoices
