lockrecord
The lockrecord statement attempts to lock the current record, and waits if it is currently locked by another user.
This statement attempts to lock the current record. If the record is already locked by another user, the procedure displays a dialog and waits for the record to become available.
let ReceivedQuantity=""
gettext "How many "+Item+" were received?",ReceivedQuantity
ReceivedQuantity=val(ReceivedQuantity)
LockRecord
if error
message “These items could not be added to the database quantity. “+
“Be sure to process them again later.“
rtn
Qty=Qty+ReceivedQuantity
UnlockRecord
If you don’t want the code to wait if the record is locked, use the lockorstop statement or the lockcurrentrecord( functionn.
- Web Cookies -- web cookies.
10.2 | No Change | Carried over from Panorama 6.0. |
