resetallrecordidts
The resetallrecordidts statement resets the internal record id and time stamps for every record in the current database.
This statement resets the internal record id and time stamps for every record in the current database. Warning: You should never use this statement. It is for internal use by ProVUE Development only, if not used correctly, it will corrupt your database.
