setwaitinglocal
TASKID
The setwaitinglocal statement assigns a value to a local variable in the parent procedure of an asynchronous task, allowing the asynchronouse code to pass a value back to the code that spawned it.
taskid – the ID of the task to wait for (either a timer or a urltask().
This statement assigns a value to a local variable in the parent procedure of an asynchronous task, allowing the asynchronouse code to pass a value back to the code that spawned it (and creating the variable if necessary). This variable can be accessed after the waitfortask statement. Normally this would be used immediately before a resumeaftertask statement, to convey status information about the results of the asynchronous task back to the caller that invoked the asynchronous process.
waitfortask urltask(someurl,"code",{... setwaitinglocal «taskid»,"_urlResult","OK" resumeaftertask «taskid»}
if _urlResult<>"OK"
... uh-oh, something went wrong in the async code
return
... everything ok
See the waitfortask documentation to learn more about coordinating synchronous and asynchronous code.
- info("computername") -- returns the name of the computer (as set up in the System Preferences Sharing panel).
- quit -- quits Panorama.
- Timer Workshop -- provides a tool for monitoring timers and testing timer configurations.
- timerexists( -- checks to see whether a timer exists.
- Timers -- executing recurring periodic background code at fixed intervals.
- Understanding the Run Loop -- explanation of how Panorama code interacts with the run loop to respond to mouse clicks, keyboard presses, display updates and other events that require attention.
- wait -- pauses the program for a specified period of time.
