makeformwebtemplate
TEMPLATE
The makeformwebtemplate statement converts a Panorama form into the equivalent HTML/CSS.
template – dictionary that controls form rendering
This statement converts a Panorama form into the equivalent HTML/CSS.
The dictionary contains options for controlling the form rendering and on exit will contain the resulting HTML/CSS code.
- HTML -> Result is placed here.
- BottomMargin -> Height of template in pixels.
- LeftMargin -> Left edge of template in pixels.
- SourceText -> If present, overall template for form page. Must contain
<style></style>
and <form></form>
. May also contain <title></title>
- SourceFile -> Path (opt) and name of template file. Only used if TEMPLATE is blank.
- AlternateFonts -> List of fonts (cr separated) with possible alternate fonts (comma separated). See alternate fonts in source code.
- Replacements -> List of text replacements.
- InputWidthFactor -> width (pixels) of a column for
<input>
tag, default is 7.25.
- TextAreaFactor -> width (pixels) of a column for
<textarea>
tag, default is 7.75.
- FormAction -> Url of action to take when form is submitted.
If action matches
then /cgi-bin/Panorama.cgi
is added to beginning of action URL.
If action matches ~*
then /cgi-bin/Panorama.cgi?databasename
is added to begining of action URL.
- FormActionParameters -> any additional parameters in the action tag.
- FormTitle -> Form title (optional)
- FormPrefix -> HTML to be inserted immediately after the
<form>
tag
- FormSuffix -> HTML to be inserted immediately before the
</form>
tag
10.2 | Updated | Carried over from Panorama 6.0, but with significant changes. |
