webthisrecordkey
FIELDS
KEY
The webthisrecordkey statement makes a key for use with the WebURLSelect statement to specify the current record.
fields – Carriage return delimited list of fields to include in the key. Note: You should not use any fields that might contain carriage returns as key fields. Note: If this is a shared database you can generate a key for the current record by specifying ""
for the field list.
key – field or variable to receive key value.
This statement makes a key for use with the WebURLSelect statement to specify the current record.
webthisrecordkey "Name"+cr()+"Zip"+cr()+"Phone",webkey
Later, you can select this record again with the weburlselect statement.
weburlselect webkey
- Web Cookies -- web cookies.
10.2 | No Change | Carried over from Panorama 6.0. |
