getlocalclick
VERTICAL
HORIZONTAL
The getlocalclick statement returns the location of the most recent mouse click in local coordinates (coordinates from the top left corner of the current form).
vertical – field or variable in which the vertical coordinate will be placed.
horizontal – field or variable in which the horizontal coordinate will be placed
This statement is used to capture coordinates of the most recent mouse click. It is intended that this statement be used in a procedure that is triggered by a button on a form (or any form object that triggers a procedure).
This example checks to see if the mouse was clicked more than 5 points away from the previous mouse click.
fileglobal mouseV,mouseH
local newV,newH
define mouseV,0 // default value if first click
define mouseH,0
getlocalclick newV,newH
if abs(newV-mouseV)>5 or abs(newH-mouseH)>5
message "Clicked far away"
mouseV=newV // new click becomes old for next time
mouseH=newH
The coordinates returned by the getlocalclick statement can be passed directly to the popup statement.
