uprecord
The uprecord statement moves the cursor up one visible record.
The uprecord statement moves up one record in the current database. If the currently active record is already the first record in the database this statement will do nothing. You can check whether this happened with the info(“stopped”) function.
- field -- tells Panorama to move to the specified field for the current record.
