ifselect
CONDITION
The ifselect statement combines the select and if info(“empty”) operations into a single statement.
condition – is a Boolean formula (a formula with a true/false result).
This statement selects a subset of database records using a Boolean formula. If no records match, the statements following the ifselect statement are skipped up until the next else or endif statement.
This example selects all records for John Smith and marks them as Cancelled. However, if there is no one in the database with that name, the message Not found is displayed.
ifselect Customer = "John Smith"
    field Status
    formulafill "Cancelled"
else
    message "Not found"
This statement is a combination of the if, select and info(“empty”) statements.
