The recompiledatabase statement recompiles all of the procedures in a specified database.
This statement has two parameters:library – name of the database to scan. If this parameter is “” or missing, the current database will be recompiled.
errors – optional parameter specifying a field or variable. If specified, a list of compile errors will be placed in this field or variable. The list is a carriage return delimited array, with one line for each procedure containing an error. Each line is a tab delimited array containing the procedure name and the error message.
This statement recompiles all of the procedures in a specified database. This example compiles all of the procedures in the current database. If any of them contains an error, they are listed.
local compileErrors
recompiledatabase "",compileErrors
if compileErrors<>""
superchoicedialog replace(compileErrors,tab(),":")
