The textlisttableoptions statement sets up text list table options
This statement has two parameters:object – name or ID of a Text List Object (must be in current form).
options – an optional string that contains tags to control the appearance of the table. See below for a description of the available tags.
This statement sets up the table appearance of a Text List Object. The first parameter identifies the Text List Object. Usually it is the name of the object, but it could also be the object ID number.
The second parameter is text that contains one or more tags for modifying the table appearance and operation. Each tag takes the form option=value. If the value contains spaces or other punctuation, it should be quoted (of course you’ll have to use a different type of quotes than are used for the entire parameter).
Here is a typical example:
textlisttableoptions "Price List",{
    widthunits=characters
    column=Item width=20 align=left
    column="List Price" width=12 align=right
A table can contain one or more columns (if no columns are specified, the table will have one column). Each column is identified by a separate column= tag. This example defines a table with 5 columns. Since no widths or alignments are specified, defaults will be used.
textlisttableoptions "Contacts",{
    column=Name
    column=Address
    column=City
    column=State
    column="Zip Code"
You can add tags for width and/or alignment. The only caveat is that if you add a width or alignment specification for any column, you must do it for all columns. This example will not work properly:
    column=Item
By default, widths are expressed in characters. This is the approximate width needed to display a certain number of characters. Please keep in mind that this is approximate, and the exact number of character that will fit depends on the characters and the font. The nice thing about specifying the width in characters, however, is that the width will adjust automatically if you change the font size.
If you want to specify the width precisely, you can use the widthunits= tag to set the width to points, inches, centimeters (or cm) or characters.
    widthunits=inches
    column=Name width="1.5"
    column=Address width="2.5"
    column=City width="2.0"
    column=State width="0.5"
    column="Zip Code" width="1.0"
An alternate notation is available that allows all of the columns to be specified in a single columns= tag. When using this tag, each column name is separated by a comma.
    columns="Name,Address,City,State,Zip Code"
You can also add width and alignment options to each column (alignment may be c or center, or r or right). When using this alternate notation it’s ok to specify the width and/or alignment for some columns but not others (the default width is 10, left aligned).
    columns="Name:12, Street:18, City:15c,State:4c,Zip:6c"
The widths are normally specified in characters, but you can use the widthunits= tag to choose other options (see above).
There are several tags that modify the appearance of the table.
TableHeader= This tag controls whether or not the column names are displayed at the top of the table. If column names are specified they are normally displayed, but you can turn this off with off, false or no.
    tableheader=off
AlternatingColors= This tag controls whether or not the table rows are displayed in alternating colors (white and light gray). This is the default for multi-column tables, but you can turn this off with off, false or no. Single column tables are usually displayed with a white background, but you can turn on alternating colors with on, true or yes. (You might want to turn off alternating colors if you are displaying a grid, see below).
    alternatingcolors=off
VerticalGrid= This tag can be used to enable a vertical grid line between each column.
HorizontalGrid= This tag can be used to enable a solid horizontal grid line between each row.
DashedGrid= This tag can be used to enable a dashed horizontal grid line between each row.
TableTextSize= This tag controls the text size of the table. The available choices are Small, Medium (the default) and Large.
    tabletextsize=small
The table always includes a vertical scroll bar, and normally also includes a horizontal scroll bar if there is more than one column. You can disable the horizontal scroll bar with the horizontalscroll tag.
    horizontalscroll=off
If you want low profile scroll bars, use the scroll=thin tag.
    scroll=thin
You can sort the data before you pass it to the table, but the table can also sort (and optionally deduplicate) the data for you.
Sort Setting this tag to on, true or yes tells Panorama to sort the table.
DeDuplicate Setting this tag to on, true or yes tells Panorama to sort and deduplicate the items in the table.
Normally you can select one row at a time by clicking on it. Use these tags to modify that behaviour.
MultipleSelection Setting this tag to on, true or yes allows multiple rows to be selected by holding down the Shift or Command keys.
EmptySelection Setting this tag to on, true or yes allows zero rows to be selected. You can do this by holding down the Command key and clicking on the selected row.
KeyboardSelection Setting this tag to on, true or yes allows rows to be selected via the keyboard. Click once to give the table focus, then start typing to select the item you want.
| Version | Status | Notes |
