appenddictionaryvalue
DICTIONARY
KEY
SEPARATOR
VALUE
The appenddictionaryvalue statement appends a value to an item in a dictionary (see Data Dictionaries).
dictionary – name of the field or variable that contains the dictionary (must contain binary data).
key – is the name of the key for the item you want to change.
separator – is the separator for new value (or “” if no separator should be used).
value – new value to append to the dictionary item.
This statement appends a value to an item in a dictionary. This example adds a new line to the Log item in the operation dictionary.
appenddictionaryvalue operation,"Log",cr(),"Received at 10:45 AM"
10.0UpdatedCarried over from Panorama 6.0, but uses new internal dictionary format
