checkserversynchronization
DEPTH
The checkserversynchronization statement checks the synchronization of the current database.
depth – the number of recent records to be checked (or 0 for all records).
This statement checks the synchronization of the local copy of the current database vs. the server. For example, this statement checks the ten most recently changed recorsds.
checkserversynchronization 10
- Web Cookies -- web cookies.
