defaultcase
The defaultcase statement works together with the case statement to specify statements that will be executed if none of the case statements are true.
The defaultcase statement identifies a section of code to be executed if none of the case statements in a group are true. The defaultcase statement should be used before the endcase statement, but after the last case statement. See the case statement for more details and examples.
- quit -- quits Panorama.
