uploadnewdatabasegeneration
NOTES
The uploadnewdatabasegeneration statement uploads a new generation of the current database to the server (must be a shared database).
notes – new generation notes (if blank, use any notes submitted with startnewdatabasegeneration).
This statement finishes the process of uploading a new generation of the current database to the server. The current database must already be shared on the server. This statement can only be used in concert with the startnewdatabasegeneration statement, see the documentation for that statement for example code.
- Web Cookies -- web cookies.
