letfileglobal
VARIABLE
VALUE
The letfileglobal statement creates a fileglobal variable and assigns a value to it.
variable – is the name of the variable that you want to create.
value – calculates the value that will be placed into the variable.
This statement works just like an assignment, but the destination of the assignment is automatically created (if it does not already exist) as a fileglobal variable. For example, this statement creates a fileglobal variable named pageCount and assigns the value 23 to it.
letfileglobal pageCount=23
The value can be any data type, for example text like this:
letfileglobal userName="Bob"
Note: This statement is identical to the assignfileglobal statement, but letfileglobal uses an equal sign between the variable name and the value, instead of a comma.
