linescontain(
LINES
VALUE
The linescontain( function checks to see if any line in a carriage return separated array matches the specified value.
lines – text with multiple lines, separated by carriage returns.
value – value to look for. For the function to return true, the value must exactly match one of the lines in the text, including upper and lower case.
This function checks to see if any line in a carriage return separated array matches the specified value.
linescontain("a
b
c","b") ☞ -1 (true)
linescontain("a
b
c","3") ☞ 0 (false)
arraycontains(thelines,thevalue,cr())
- + -- works differently depending on the type of operands used with it.
If both operands are numeric, it does numerical addition.
If either operand is text the + operator concatenates (joins together) the two operands.
- beginswith -- returns true if the value on the left starts with
the value on the right, false if it doesn't.
- contains -- returns true if the value on the left contains
- decrypt( -- decrypts data.
- encrypt( -- encrypts data.
- endswith -- returns true if the value on the left ends with
- notcontains -- returns true if the value on the left does not contain
the value on the right, false if it does.
- tab( -- generates a tab.
