alphabeticnumber(
VALUE
The alphabeticnumber( function converts a number into letters: A, B, C, etc.
value – number to convert.
This function converts a number into one or more upper case letters. Numbers from 1 to 26 are converted into single letters, larger numbers are converted into two or more letters.
alphabeticnumber(1) ☞ A
alphabeticnumber(2) ☞ B
alphabeticnumber(26) ☞ Z
alphabeticnumber(27) ☞ AA
alphabeticnumber(28) ☞ AB
