tsvtojson(
TSVTEXT
The tsvtojson( function converts tab separated text into JSON formatted text.
tsvtext – text containing tab separated values. The first line of text contains the titles for each column of text. Each subsequent line must contain the actual data items in the same order. The lines must be separated by carriage returns.
This function converts tab separated text into JSON code. For example, suppose you have a tab file named Directory.tsv that contains data like this (the ▷ symbol represents tab characters):
Name ▷ Phone ▷ Email
Adams, Dorothy ▷ 555-3000 ▷ dadams@gmail.com
Franklin, Mark ▷ 555-4822 ▷ mfranklin@hotmail.com
Smith, John ▷ 555-1212 ▷ jsmith@yahoo.com
Wilson, Judy ▷ 555-9324 ▷ jwilson@acme.net
This data can be read into a variable and converted to comma separated format:
local phoneNumbers
phoneNumberJSON=tsvtossv(fileload("Directory.tsv"))
The phoneNumberJSON variable now contains the same data, but converted into JSON format (the JSON format is frequently used in web coding).
"Name" : "Adams, Dorothy",
"Phone" : "555-3000",
"Email" : "dadams@gmail.com"
"Name" : "Franklin, Mark",
"Phone" : "555-4822",
"Email" : "mfranklin@hotmail.com"
"Name" : "Smith, John",
"Phone" : "555-1212",
"Email" : "jsmith@yahoo.com"
"Name" : "Wilson, Judy",
"Phone" : "555-9324",
"Email" : "jwilson@acme.net"
- csvexportline( -- generates a comma delimited line of data containing all the fields in the current record.
- csvexportlinevisiblecells( -- generates a comma delimited line of data containing all the visible (non hidden) fields in the current record.
- csvquoted( -- adds quotes if necessary for CSV text (RFC 4180).
- HTML Export -- custom exports into an HTML file.
- Import Database -- importing another database into the current database.
- import( -- returns a line or element of imported data. This function works in conjunction with repetitive operations like importtext, arrayfilter(, characterfilter( etc.
- seq( -- returns sequential numbers (1, 2, 3, etc.).
- Text Export -- exporting a database into a text or HTML file.
- Text Export Wizard -- custom exports into a text or HTML file.
- Text Import -- importing text into an existing database.
