WORD1
 soundslike
WORD2
The soundslike operator compares two words to see if they “sound like” each other.
This operator has two  parameters:
word1 – The first word.
word2 – The second word.
The soundslike operater converts two words (text) to a phonetic codes using the soundex algorithm. This algorithm, originally created in 1918, attempts to create the same code for words that sound similar in English. The algorithm only works properly for English, and only for one word at a time, so each operand should be just one word. Finally the soundslike operator compares the codes to see if the words have similar pronunciations.
soundslike("smith","smythe") ☞ true
soundslike("katy","katie") ☞ true
soundslike("john","JON") ☞ true
soundslike("christy","christy") ☞ true
One weakness of this algorithm is that the two words must start with the same letter for the phonetic code to match. Because of this, word pairs like Christy and Kristy will not match.
Note: The soundex algorithm is not very exact, and often will produce extra matches that you might not think really sound similar. However, it almost never fails to match on names that do sound similar, so it is a good starting point when you are not sure of an exact spelling.
- beginswith -- returns true if the value on the left starts with
the value on the right, false if it doesn't.
- contains -- returns true if the value on the left contains
- endswith -- returns true if the value on the left ends with
- notcontains -- returns true if the value on the left does not contain
the value on the right, false if it does.
