commalist(
ARRAY
SEPARATOR
The commalist( function converts a text array (see Text Arrays) into an English list, with items separated by a comma and a space, except for the last two items which are separated by the word and and spaces.
array – the array containing the list of items.
separator – the separator character.
This function converts a text array (see Text Arrays) into an English list, with items separated by a comma and a space, except for the last two items which are separated by the word and and spaces.
commalist("red/green/blue","/") ☞ red, green and blue
commalist("black-white","-") ☞ black and white
commalist("gold",",") ☞ gold
?(thetext contains thesep,replace(arrayrange(thetext,1,-2,thesep)+
" and "+array(thetext,-1,thesep),thesep,", "),thetext)
