linestrip(
TEXT
The linestrip( function removes any blank lines from the text.
text – text with one or more lines.
This function removes any blank lines from the text.
linestrip(Letter) ☞ contents of Letter with blank lines removed
arraystrip(thetext,cr())
- decrypt( -- decrypts data.
- encrypt( -- encrypts data.
- tab( -- generates a tab.
