hexlong(
VALUE
The hexlong( function converts a decimal number to an eight-digit hexadecimal number expressed as a text string
value – is the number you want to convert to hexadecimal. The value should be from 0 to 4294967295.
Converts a decimal number to an eight-digit hexadecimal number expressed as a text string. See Non Decimal Numbers for background information on hexadecimal numbers.
hexlong(68) ☞ 00000044
hexword(50000) ☞ 0000C350
hexword(50000000) ☞ 02FAF080
radixstr("hex",number)[-8,-1]
