trim(
TEXT
COUNT
The trim( function removes characters from the right edge of the text.
text – original text.
count – number of characters to remove from the original text.
This function removes one or more characters from the right edge of the text. For example trim(text,4) removes the last four characters from the text.
trim("abcdef",1) ☞ abcde
trim("abcdef",2) ☞ abcd
trim("abcdef",12) ☞
If you want to trim characters from the beginning of the text, use the trimleft( function.
text[1,-1-count]
- decrypt( -- decrypts data.
- encrypt( -- encrypts data.
- tab( -- generates a tab.
