arraymerge(
ARRAY1
ARRAY2
SEPARATOR
JOINER
The arraymerge( function merges two text arrays together (see Text Arrays).
array1 – is the first text array.
array2 – is the first second array.
separator – is the separator character for both arrays (both must use the same separator character). This should be a single character.
joiner – is the text that will be used to join the individual elements of the two arrays. If the joiner is empty (“”) then the elements will simply be appended.
The arraymerge( function merges two text arrays together, item by item (see Text Arrays). In other words, the first element of the first array is merged with the first element of the second array, then the second elements of each array are merged, then the third elements, fourth elements, etc.
arraymerge("1,2,3","red,green,blue,orange,black",",",":") ☞ 1:red,2:green,3:blue,:orange,:black"
arraymerge("1,2,3,4,5,6","Gold,Silver,Bronze",",",". ") ☞ 1. Gold,2. Silver,3. Bronze,4. ,5. ,6. "
arraymerge("1,2,3","A,B,C",",","") ☞ 1A,2B,3C
10.0UpdatedCarried over from Panorama 6.0, but the joiner text is no longer limited to 10 characters.
