applescriptstring(
TEXT
The applescriptstring( function converts text into an AppleScript string literal.
text – the original text.
This function converts text into an AppleScript string literal. To do this the function surrounds the text with double quote characters, and escapes any double quote and/or backslash characters within the text. Use this function when you need a string literal inside the applescript statement or applescript( function.
applescriptstring({Make text into "applescript literal", including \ characters.})
    ☞ "Make text into \“applescript literal\“, including \\ characters."
{"}+replace(replace(thetext,{\},{\\}),{"},{"})+{"}
