VALUE1
VALUE2
The >= operator compares two values to see if the first value is greater than or equal to the second value.
value1 – The first numeric or text value.
value2 – The second numeric or text value.
The >= operator compares two values to see if the first is greater than or equal to the second. The two values can be either text or numeric, but they must both be the same type. The result is true if the first value is greater than or equal to the second, and false if the first is less than the second. Here are some examples:
73 >= 34 ☞ true
34 >= 45 ☞ false
56 >= 56 ☞ true
"xyz" >= "abc" ☞ true
"abc" >= "xyz" ☞ false
"abc" >= "abc" ☞ true
"123" >= 123 ☞ error
There are two alternate spellings available: isgreaterthanorequalto and ≥ (Option->).
598 isgreaterthanorequalto 447 ☞ true
"abc" ≥ "def" ☞ false
Note: The Boolean values true and false are actually integer (numeric) values -1 and 0.
Error Messages
Cannot compare text with number. – Both parameters must be the same data type. If one is text and the other is numeric, the result is this error.
- and -- returns true if both operands are true.
- false( -- returns false.
- not -- reverses a boolean value.
- not( -- reverses a Boolean value
- or -- returns true if either operand is true, or false if both are false.
- switch( -- chooses from a list of values.
- true( -- returns true.
- xor -- returns true if one of the two parameters is true, false if neither or both are true.
| 10.0 | Updated | Carried over from Panorama 6.0, but now allows alternate spelling |
