VALUE1
beginswith
VALUE2
The beginswith operator returns true if the value on the left starts with
the value on the right, false if it doesn’t.
value1 – The first numeric or text value.
value2 – The second numeric or text value.
The beginswith operator compares two values (usually text) to see if the value on the left starts with the value on the right.
"abcdef" beginswith "abc" ☞ true
"abcdef" beginswith "bcd" ☞ false
12345 beginswith 12 ☞ true
12345 beginswith 23 ☞ false
As the final two examples show, the beginswith operator can work with numbers as well as text – it simply automatically converts the number into text before comparing.
As a more practical example, the formula below will be true if the Address field or variable starts with the letters p.o. box.
Address beginswith "p.o. box"
This formula will be true if the if the address is P.O. Box 5328, and false if the address is 6938 Wilson Road.
Note: The beginswith operator does not worry about upper or lower case, so P.O. BOX 5328 or p.o. box 5328 will also produce true results. If upper and lower case are important to you use the matchexact operator.
- contains -- returns true if the value on the left contains
the value on the right, false if it doesn't.
- endswith -- returns true if the value on the left ends with
- notcontains -- returns true if the value on the left does not contain
the value on the right, false if it does.
10.0 | Updated | Carried over from Panorama 6.0, but also now allows numeric as well as text parameters. |
