trimstart(
TEXT
COUNT
The trimstart( function removes one or more characters from the start of the text.
text – the original text.
count – the number of characters to remove.
Removes characters from the start of the text. For example trimstart(text,2) removes the first two characters from the text.
trimstart("abcd",1) ☞ bcd
trimstart("abcd",2) ☞ cd
thetext[count+1,-1]
- decrypt( -- decrypts data.
- encrypt( -- encrypts data.
- tab( -- generates a tab.
