snip(
THETEXT
STARTPOSITION
COUNT
The snip( function removes (snips!) one or more characters from the middle of an item of text.
thetext – the original text
startposition – the position of the first character to be removed. The position must be a positive number 1 or greater (1 corresponds to the first character of the original text).
count – the number of characters to remove. If the count is -1 then all the text from the start position to the end of the text is snipped, otherwise the count must be a positive number.
This function removes (snips!) one or more characters from the middle of an item of text.
snip("abcdefghi",4,3) ☞ abcghi
snip("abcdefghi",2,7) ☞ ai
snip("abcdefghi",4,-1) ☞ abc
thetext[1;startposition-1]+?(count=-1,"",thetext[startposition+count,-1])
- decrypt( -- decrypts data.
- encrypt( -- encrypts data.
- tab( -- generates a tab.
