commatocr(
TEXT
The commatocr( function converts a comma delimited array into a carriage return delimited array.
text – original text, containing zero or more commas.
This function converts a comma delimited array into a carriage return delimited array.
commatocr("a,b,c") ☞ a↩b↩c
replace(thetext,",",cr())
