quoted(
TEXT
The quoted( function returns a quoted version of the supplied text.
text – the original text
This function surrounds the supplied text with double quote characters ("). If the original text contains any double quotes they will be doubled, making this a legal string constant (which could be used in an execute statement, for example).
quoted({Hello World}) ☞ "Hello World"
quoted({Add "quotes" to text}) ☞ "Add ""quotes"" to text"
{"}+replace(thetext,{"},{""})+{"}
- + -- works differently depending on the type of operands used with it.
If both operands are numeric, it does numerical addition.
If either operand is text the + operator concatenates (joins together) the two operands.
- beginswith -- returns true if the value on the left starts with
the value on the right, false if it doesn't.
- contains -- returns true if the value on the left contains
- decrypt( -- decrypts data.
- encrypt( -- encrypts data.
- endswith -- returns true if the value on the left ends with
- notcontains -- returns true if the value on the left does not contain
the value on the right, false if it does.
- tab( -- generates a tab.
