wordcount(
TEXT
The wordcount( function returns the number of words in the text.
This function has one  parameter:
text – text with words to count.
This function counts the number of words in the text.
wordcount("now is the time") ☞ 4
wordcount("or is this the time, or now?") ☞ 7
extract(arraystrip(replacemultiple(thetext,cr()+":"+tab()+":"+chr(10)," : : ",":")," ")," ",-1)
- + -- works differently depending on the type of operands used with it.
If both operands are numeric, it does numerical addition.
If either operand is text the + operator concatenates (joins together) the two operands.
- beginswith -- returns true if the value on the left starts with
the value on the right, false if it doesn't.
- contains -- returns true if the value on the left contains
- decrypt( -- decrypts data.
- encrypt( -- encrypts data.
- endswith -- returns true if the value on the left ends with
- notcontains -- returns true if the value on the left does not contain
the value on the right, false if it does.
- tab( -- generates a tab.
