lastline(
TEXT
The lastline( function extracts the last line from the text.
text – the original text, with multiple carriage return separated lines.
This function extracts the last line from the text.
lastline("red
green
blue
yellow
orange") ☞ orange
array(thetext,arraysize(thetext,cr()),cr())
- decrypt( -- decrypts data.
- encrypt( -- encrypts data.
- tab( -- generates a tab.
