left(
TEXT
LENGTH
The left( function extracts characters from the left edge of the text.
text – original text
length – number of characters to extract from beginning of the original text. Any characters beyond the length will be discarded.
This function extracts one or more characters from the left edge of the text.
left("abcdef",1) ☞ a
left("abcdef",3) ☞ abc
left("abcdef",12) ☞ abcdef
text[1;length]
- decrypt( -- decrypts data.
- encrypt( -- encrypts data.
- tab( -- generates a tab.
