info("defaultfloatformat")
The info(“defaultfloatformat”) function returns the default format for converting floating point numbers to text.
This function returns the current default format for converting floating point numbers to text:
info("defaultfloatformat") ☞ %.15g
See setdefaultfloatformat to learn more about the floating point format and how to change it.
