firstword(
TEXT
The firstword( function extracts the first word from the text.
text – original text.
Extracts the first word from the text.
firstword("now is the time") ☞ now
firstword("Mary Wilson") ☞ Mary
firstword("Wilson, Mary") ☞ Wilson,
If you want only alphabetic characters, use the striptoalpha( function.
striptoalpha(firstword("Wilson, Mary")) ☞ Wilson
array(text,1," ")
- decrypt( -- decrypts data.
- encrypt( -- encrypts data.
- tab( -- generates a tab.
