boolstr(
BOOLEAN
The boolstr( function converts a Boolean value to text, either "true" or "false".
boolean – the true/false value (0=false, -1 = true)
This function converts a Boolean value to text, either "true" or "false".
boolstr(1=1) ☞ true
boolstr(1=2) ☞ false
?(thenumber=true(),"true","false")
