hexword(
VALUE
The hexword( function converts a decimal number to a four-digit hexadecimal number expressed as a text string.
value – is the decimal number you want to convert to hexadecimal. The value must be from 0 to 65535.
Converts a decimal number to a four-digit hexadecimal number expressed as a text string. See Non Decimal Numbers for background information on hexadecimal numbers.
hexword(68) ☞ 0044
hexword(50000) ☞ C350
radixstr("hex",number)[-4,-1]
