VALUE1
VALUE2
The = operator compares two values to see if they are the same.
value1 – The first numeric or text value.
value2 – The second numeric or text value.
The = operator compares two values to see if they are equal (the same). The result is true if the values are the same and false if they are different. If text values are compared, the result will only be true if the two values are exactly the same, including upper and lower case (use the match operator if you want to ignore case). Here are some examples:
34 = 34 ☞ true
34 = 45 ☞ false
"abc" = "abc" ☞ true
"abc" = "xyz" ☞ false
"abc" = "ABC" ☞ false
"123" = 123 ☞ false
You can also spell out the operator name, like this:
984 isequalto 984 ☞ true
"abc" isequalto "xyz" ☞ false
Note: The Boolean values true and false are actually integer (numeric) values -1 and 0.
Note: If you are a “C” programmer, Panorama’s =
operator is equivalent to C’s ==
operator. (In fact, Panorama will allow you to use ==
if you wish.)
- and -- returns true if both operands are true.
- beginswith -- returns true if the value on the left starts with
the value on the right, false if it doesn't.
- contains -- returns true if the value on the left contains
- endswith -- returns true if the value on the left ends with
- false( -- returns false.
- not -- reverses a boolean value.
- not( -- reverses a Boolean value
- notcontains -- returns true if the value on the left does not contain
the value on the right, false if it does.
- or -- returns true if either operand is true, or false if both are false.
- switch( -- chooses from a list of values.
- true( -- returns true.
- xor -- returns true if one of the two parameters is true, false if neither or both are true.
10.0 | Updated | Carried over from Panorama 6.0 but no longer results in an error if there is a type mismatch -- instead simply returns false. |
