htmltablecell(
TABLE
ROW
COLUMN
The htmltablecell( function extracts the data from a cell in an HTML table.
table – text of the HTML table. This parameter must contain the body of an HTML table with <tr> and <td> tags (however, the actual <table> and </table> tags themselves are not required.
row – row number within HTML table. Rows are numbered starting from 1.
column – column number within HTML table. Columns are numbered starting from 1.
This function extracts the data from a cell in an HTML table. Any tags in the cell are removed, leaving only the actual text. Suppose you set up a variable with an HTML table, like this:
local htable
htable =
   "<tr><td><font size=-1>Alaska</font></td><td>AK</td></tr>
    <tr><td><font size=-1>Arizona</font></td><td>AR</td></tr>
    <tr><td><font size=-1>Wyoming</font></td><td>WY</td></tr>"
Once this variable is set up, you can extract different table elements using the htmltablecell( function.
htmltablecell(htable,2,1) ☞ Arizona
htmltablecell(htable,3,2) ☞ WY
This function removes any HTML tags that may have been in the cell. If you need the tags as well as the text, use the htmltablecellraw( function.
htmltablecellraw(htable,2,1) ☞ <font size=-1>Arizona</font>
htmltablecellraw(htable,3,2) ☞ WY
strip(tagstrip(arrayrange(tagdata(tagdata(thetable,"<tr","</tr>",row),"<td","</td>",col),2,9999,">"),"<",">"))
