VALUE1
VALUE2
The <> operator compares two values to see if they are different.
value1 – The first numeric or text value.
value2 – The second numeric or text value.
The <> operator compares two values to see if they are different. The result is true if the values are different and false if they are the same. If text values are compared, the result will only be false if the two values are exactly the same, including upper and lower case (use the notmatch operator if you want to ignore case). Here are some examples:
34 <> 34 ☞ false
34 <> 45 ☞ true
"abc" <> "abc" ☞ false
"abc" <> "xyz" ☞ true
"abc" <> "ABC" ☞ true
"123" <> 123 ☞ true
You can also spell out the operator name or use the ≠ symbol or != symbol, like this:
984 isnotequalto 984 ☞ false
"abc" ≠ "xyz" ☞ true
8309 != 2389 ☞ true
Note: The Boolean values true and false are actually integer (numeric) values -1 and 0.
Note: If you are a “C” programmer, Panorama’s = operator is equivalent to C’s != operator. (In fact, Panorama will allow you to use != if you wish, and you can also use ≠ by pressing OPTION-=.)
- and -- returns true if both operands are true.
- false( -- returns false.
- not -- reverses a boolean value.
- not( -- reverses a Boolean value
- or -- returns true if either operand is true, or false if both are false.
- switch( -- chooses from a list of values.
- true( -- returns true.
- xor -- returns true if one of the two parameters is true, false if neither or both are true.
| 10.0 | Updated | Carried over from Panorama 6.0 but no longer results in an error if there is a type mismatch -- instead simply returns true (i.e. not equal). |
