defaulttext(
DEFAULT
TEXT
The defaulttext( function returns a text value, or returns a default value if the text value is empty (“”).
default – default value to use if the second parameter is empty.
text – primary text value
This function returns a text value, or returns a default value if the text value is empty (“”).
defaulttext("714","213") ☞ 213
defaulttext("714","") ☞ 714
?(thetext="",thedefault,thetext)
- decrypt( -- decrypts data.
- encrypt( -- encrypts data.
- tab( -- generates a tab.
